Supercharger oil change kit. S-type R, XKR, X308R, X350R
Postby J44EAG » Sun Nov 13, 2011 9:32 pm
AGS
Re: Supercharger oil change kit. S-type R, XKR, X308R, X350R
Postby AGS » Fri Feb 06, 2015 12:58 pm
Is this an easy job? :-)
AGS
2002 STR 4.2
Postby J44EAG » Fri Feb 06, 2015 5:50 pm
You will almost certainly need a syringe to extract the old oil and replace it with new. Expect the old oil to come out like gravy! Obviously if the oil has some heat in it that will help extraction.
I`m unsure whether you may be able to use a vacuum oil extractor such as a Pella unit. Might be quicker and cleaner than the syringe method.
I`ve used the syringe method on an X300 SC car which had an M90 super charger. The M112 which I think is very similar on an STR is apparently not much different but delivers rather more pressure than the M90.
Hope that helps.
Montana5
Postby Montana5 » Fri Feb 06, 2015 11:54 pm
Not something I have done yet and the kit looks appealing, was going to leave it to perhaps later this year and have the oil and SC Bearings changed at the same time, plus for extra peace of mind have the infamous Valley Pipe changed, while the Supercharger is off.
I get e-mail updates from the site Mike linked to, they are the place to go for performance mods, uprated SC Pulley Wheels etc, don't get me wrong I'm quite happy with 400 BHP, think they also stock the Gator Belts which are highly recommended.
Doug.
S Type Forum Moderator
