Car stops unexpectedly, but restarts .
nigel8578230
Postby nigel8578230 » Sun Apr 11, 2021 4:57 pm
Hi All i have an s type 04 diesel, on very random drives the car will just turn its self off usually at a turning or roundabout. Given A couple of minutes it will restart ,clear the dash warnings and go along fine. has anyone come across this happening or has anyone got any clues.
Other than this she drives exceptionally well.
jeff1954
Re: Car stops unexpectedly, but restarts .
Postby jeff1954 » Wed Apr 14, 2021 6:45 pm
Hi This sounds like a wiring problem behind the front bumper. I've read about it before ( could be on this forum ) It's a case of removing the front bumper and doing a continuity test on the all the wires to find a break in one of them. Apparently it is quite a common problem especially on early models.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
nigel8578230
Postby nigel8578230 » Wed Apr 14, 2021 6:55 pm
Many thanks Jeff apoint in the right direction,in all the paperwork that came with the car the previous owner had tried unsuccessfully to get the fog lights working so it my be connected.
nigel
jeff1954
Postby jeff1954 » Thu Apr 15, 2021 5:58 pm
Ok If it is a wiring fault behind the bumper, it's not as daunting as it sounds. The bumper comes off in one piece. I never had to remove mine, but there's info on here how to do it. Apparently some of the fixings can rust and be hard to release but once it's off you will be able to attend to them.
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
