The V8 4 litre also has oil feed issues which were designed out on the later 4.2 52plate onwards cars.
The V8 4 litre can suffer oil starvation when cornering forces act upon the sump oil level. Let the oil level drop and the number 1 bearing starves out.
So a lesson for us all. Keep that oil level topped up. As the handbook for the car says, check oil level on a weekly basis.
Nice research and assessment, Brian. I`m sure we all agree it is most useful.
An idiot with a duff engine!
Re: An idiot with a duff engine!
I forgot to say oldtimer that I'll keep the heads, cams, buckets, chains, guides and tensioners plus the sensors from the old engine, and the rest will be made into a feature for the garden. Lesley can get 6 plant pots into the cylinders.
I did consider modifying the sump and pickup pipe to deepen the sump and hold more oil but not sure if that is the problem.
There is another difference between the engines, the 1999 engine has VVT solenoid valves without filters on them, I found one of my original valves with a bit of the filter torn off and jammed into the valve (easily pulled out).
As you will appreciate the engine failure still haunts me so to that end I have done what research I can.
The oil is drawn up by the pump on the front end of the crankshaft and from there via a large gallery it is feed to the oil filter and then on to the oil/water cooler and then in to the gallery that feeds the main and big end bearings (no drilling to feed oil to the little ends).
At failure the oil level was low i.e. 1/8" above the minimum level, which incidentally is equal to the maximum level on the pre mid 2000 'Tee bar' oil slick.
The oil filter I had on was too small physically, approx. 60% of the length of the correct Jaguar filter (meant for a 1.6 ltr engine). Also I have just measured an aftermarket filter which is physically the same size, BUT it has 6 inlet holes of 7mm dia whereas the present Jaguar filter has 8 holes 7.8mm dia.
The aftermarket filter has 60% of the flow area of the present Jaguar 3 ltr AJ-V6 filter (pictures of the earlier Jaguar filter shows 6 holes!!!!).
As the old oil cooler has had metal soup through it I cut it open, the galleries inside it will just about accept a pin into them they are so small, but there are a lot of them.
If you have ever pumped tanks out using a volute pump you will appreciate how when the level has dropped low enough it will not pick up. Our positive displacement oil pump is better but would also struggle to restart oil flow particularly as it gets older and a bit worn.
So with a new front crankshaft seal I am not using/loosing oil as before and it is staying at the maximum level on the 'ring pull' dipstick. I am using Jaguar oil filters (made in Canada apparently), but what oil to use.
I have been using Comma oil for many years without any problems and for this engine I'm using Comma X-tech 5w 30 as it is marked as up to the required ford oil spec. But this is the first engine I have had fail on me (probably my own fault due to the level and filter) I am considering going the extra mile and using Millers Oils, their new EE longlife Eco 5w 30 (Millers own recommendation).
Question:- am I being paranoid and going too far?
Question:- for those who do there own oil changes what oil do you use please?
After all oil is maintenance in a can!
Best wishes
Best wishes
Excellent post failure diagnosis, I think, Brian.
Many is the time we hear of non genuine filters not being quite what is required. For instance, the absence of a non return valve in the filter body being just one comment that I once saw.
A filter that is too small or is unable to pass a correct volume of oil will not help the situation.
Best advice then is to use a genuine filter if any doubt exists as to whether a filter from an alternative source is being considered. Being an ex Unipart man, perhaps Phil can pass comment on this subject.
Being badly bitten Brian, I don`t think you are being paranoid at all. Just cautious in the light of experience gained.
The V6 is prone to oil starvation so the modified extra deep sump can only be good. I would have thought any oil meeting the specified Jaguar recommendation should be more than good enough. I believe where things go wrong is that oil levels are left by owners to go below the lowest mark and that neglected and overly long periods of oil servicing frequently occur. Best advice is as the good book says, "Check oil weekly" and service at 10k intervals.
Difficulties arise when one buys a car without a decent oil change record. In that instance don`t buy the car or use the fact to drop a sellers price like a lead manhole cover.
Not well known is the fact that V8 4 litre models MUST have their oil kept to the maximum especially if the car is reefed around roundabouts or otherwise cornered hard. A flashing oil light indicates oil level is low and untold damage is being done to the No1 main bearing. Later 4.2 models have an improved oil pick up design.
Some members may have seen or even perhaps read my article regarding oil degradation in the November 2010 issue of our magazine. To my knowledge PTJS 1 is the only person to have attempted to read the article or comment upon it. Paul tells me he read the article whilst taking a bath during which he fell asleep and drowned his magazine. This was a shame as he was therefore unable to fully take in the contents. Be that as it may, my research for the article found that fully synthetic oil compared to semi-synthetic produced and held far less harmful gummy deposits and was less prone to burning. The conclusion was that a fully synthetic oil would remain in better condition for the service life of the oil when again compared to a semi-synthetic oil.
I question the wisdom of using semi synthetic oil in V6 or V6 Jaguar engines. Did Jaguar get it wrong? I personally only use synthetic oil which I do appreciate is a modified mineral oil. Using a synthetic product as far as I am concerned gives my hard driven engine perhaps a better chance of avoiding future oil starvation issues. Whether that will become fact or fiction will be found around 100k miles which seems to be a mileage that begins to show issues in our engines.
5W30 grade is the starting bench mark. Whether paying extra for well known brand leaders is debatable. Personally, I think it far more important to change oil at specified mileage markers or more frequently if a car is used for short journeys where fuel dilution and destructive chemicals can build up quickly and ruin an oils potential to protect.
Mike.
Mike.
Thanks for your reply Mike, If you wrote an article then I would have read it but not necessarily commented upon it.
Some years ago I read a magazine article that said for a particular grade of oil (say 5w 30) various brands would supply said grade and SAY it was fully synthetic when in fact some were mineral oil, some were semi and some fully synthetic. So maybe the situation has improved and they are what they say they are???!!!?? At the time Mobil 1 was the only real fully synthetic oil.
I agree with you Mike that a real synthetic will be better long term, but I change oil at least every year and expect the S type to do 3-5000 a year. I wish we knew what really was in the oils they sell us!
Mike /Brian.
My pal Norman used to deal with that product. I'll have a word with him first and respond later
P
P
