POA30 catalyst Efficeiency Below Threshold bank2
sheldon1
Postby sheldon1 » Thu Jun 04, 2015 1:30 pm
I recently went to a local garage and had my diagnostics checked.
Two code reading came up POA30 Catalyst Efficency Below threshold Bank 2
Second: P1388 Variable camshaft timing over retard Bank 2.
What is the best solution and for clearing these reading for a 3.0SE S type 16 years old.
Re: POA30 catalyst Efficeiency Below Threshold bank2
Postby J44EAG » Thu Jun 04, 2015 2:39 pm
Off the cuff i would be surmising that the catalyst may be somewhat choked. This does happen.
You might try a bottle of Cataclean (ebay and Halfords)to attempt to help burn out 16 years of combustion crud from the cats. It is well worth a try before perhaps considering cat replacement. use this additive exactly as per the instructions on the bottle. I have found it very effective. see my posts on the subject.
It does sound as if you may have a VVT solenoid that has become time expired. This may or may not have something to do with the cat issue. In both respects I think you need some professional advice from perhaps a local Jaguar Independent garage.
Down pipes complete with new catalytic converters are plentiful on ebay. Ensure if you have to buy one that it is of at least OE standard. careful trawling of the internet will also find you new VVT units at good prices if you search with a part number.
Fitting of these parts can be done DIY if you have the skill set and appropriate facilities and tools.
Martec
Postby Martec » Thu Jun 04, 2015 7:43 pm
The VVT problem could just be the age old problem with these of the little filter having been pushed into the valve and holding it open. I had this and when I stripped and changed the engine I found the filter in the valve, I pulled it out and the fault code has not reappeared.............yet. Incidentally the very early valves did not have a filter.
They are easy enough to get out, take the plastic cam cover off and the valve is only held in with one or two screws and it pulls out to clean.
oldtimer
Postby oldtimer » Thu Jun 04, 2015 10:36 pm
Dirty engine oil doesn't help either
sheldon1
Postby sheldon1 » Thu Jun 04, 2015 11:31 pm
Thanks, Mike , Brian & Old timer for the advice.
