S Type V6 Timing chains and tensioners
oldtimer
Postby oldtimer » Thu Oct 18, 2012 9:43 pm
Hi Mike,
I have been following the subject of timing chains and tensioners with interest. I can see there are simalarities in camshaft and chain layouts between the two. Can you say if the problems are confined to the V8 or does it apply to the V6 as well.
Oldtimer
robv12
Re: S Type V6 Timing chains and tensioners
Postby robv12 » Fri Oct 19, 2012 8:43 am
3.2 and 4.0 V8 only, the V6 is a gem of an engine, big mileages without fault are now common
Postby J44EAG » Fri Oct 19, 2012 10:17 am
Rob is totally correct. No valve gear issues with the V6.
The only issue of any magnitude with the V6 is that it can and will pick up and turn small end bearings if regular oil changing is not carried out. Other than that most other common small issues relate to wobbling crank damper pulleys at high mileages and the infamous two rubber elbow air pipes which can squash or split as an engine ages. Best to change those two elbows when spark plugs are changed and the inlet manifold is removed. To ignore is a false economy.
oldtimer
Postby oldtimer » Fri Oct 19, 2012 11:59 am
Hi Mike and Robv12,
Thanks for that,very re assuring.These days my motors suffer low milage and high oil change (annual) regardless so don't expect internal pick up.
Mike it is interesting you mentioned the wobbly crank damper. I've had that one at only 39k.
Returned off a good run, started up the next morning to a terrible variable rattle. Panic , is it internal or external. Turned out to be the belt tensioner flappimg about caused by a longitudenal split in the belt. New belt on, and thought this aint right, it's out of alinement. After much agonising discovered that the damper bonding had failed allowing the pulley to move forward about 1/4 inch.
I had noticed a couple of years back that the belt was overhanging the water pump pully by 1/16 and just thought that's a bit naff. Sits correctly now , so was a clear sign of the inpending failure
Regards Oldtimer
Martec
Postby Martec » Fri Oct 19, 2012 4:41 pm
A question please,
From the specs for V6 engines detailed in another post on this forum it says the tappets are mechanical, not hydraulic. They are very quiet, but do they need checking and I assume reshimming from time to time???
Postby J44EAG » Fri Oct 19, 2012 5:24 pm
Pretty much leave well alone unless rattling like a skeleton on a tin roof, I would have thought. I`m not aware that valve clearance servicing is needed but I will check.
Nowadays, we are lucky that this type of maintenance has been designed out. With modern engines valve type wear noises would tend to suggest an engine that is well over the hill!
I`ll see what I can find out but suspect that I may be looking for something that does not exist.
Mike.
Late edit.
Valve clearance resetting does not appear on the service schedule or would I have expected to find it there really.
The valve gear arrangement is 4 x overhead cams each individually phased to open and close the valves in the required order. Eccentric cam shaft lobes with a running clearance during their dwell periods, operate upon inverted tappet buckets under which it would appear that a selectively fitted and thicknessed shim is installed between the bucket and the valve stem.
Altering valve clearances would require removal of cams, buckets and shims. Those of you would might have maintained a Hillman Imp or Rover 2600 will be familiar with the arrangement.
With this valve gear set up, only wear on the cam, its mating bucket or after extremely high mileages, valve recession ("sinkage") into valve seats set into the cylinder head casting will cause clearances to change. Were that to be evident, then one could assume that the hardened faces of the cam lobes and buckets will have been worn through and in all likelihood, new camshafts and buckets would be needed. If that point were reached, then it would be more economical to replace the worn engine with a good second hand unit.
Just for the record clearances as follows.
Inlet 0.175-0,225mm
Exhaust 0.325-0.375mm
I just hope this is useful to someone because it certainly isn`t to me!! M
oldtimer
Postby oldtimer » Fri Oct 19, 2012 9:58 pm
Hi mike
Did'nt realise you spoke in funny money! Those clearance figures you gave don't mean a thing to me in mm , as I'm sure you know all the XK6 & V12 engines employ the shim adjusting system , never worked on an Imp, car that is. That is unless I have mis-understood your discription. I have a full set of adjusting shims 0.085-0.105, havent used them for years. In the 60s and 70s XK engines were pretty clapped at 70k/80k. The adjusting shims get indented by the tip of the valve and that will open up the clearance. Anyhow, everything else is a bit slack by then.
You know Mike with that sort of back ground I find it scary when I hear people talking about buying cars with well over 100,000 miles on the clock, I just find it hard to accept this is the norm
Oldtimer
Postby J44EAG » Fri Oct 19, 2012 10:46 pm
I fought off metric for years then had to do the operational conversion course.
I still find working micro measurements easier in imperial but larger dimensions in metric.
We can thank modern oils, finer materials and machining technology for longer lasting power units. I am of the opinion that modern cranks, bearings, pistons, rings, valves, guides and cams and so on, have a much longer life than in the sixties and seventies. This is largely due to vastly improved lubricants and +100k reliable engine life is certainly possible. As regards transmission life of an equal longevity, that is quite another matter.............
What we do all find is that although core power units last well, the issue that comes up time and time again is the matter of reliability of ancillary units. Water pumps, crank dampers, tensioners,heater valves, sensors, coils and pulley wheels being examples. Realistically, these items work with little or no maintenance and often without lubricant which reduces friction, lowers running temperatures and is a major contributory factor in the battle to combat component failure.
As a consequence of such a low level of maintenance, those tertiary parts fail with monotonous regularity and tear- jerkingly painful replacement costs. When did you last see a grease tit on a water pump for instance? Modern production methods now lead towards install and forget. When failure occurs, you just go out and buy a new one.
It is not so much fear of buying a car with a high mileage engine but terror as to what costs may be encountered fixing fairly basic components outside of the engine block itself. An S-type lower rear wishbone is just one example of the problem where to replace both rear components if sourced from Jaguar, will cost a good £1k. No wonder we tend to run scared of a high mileage car.
So suck, squeeze, bang, blow continues regardless. The age old adage of one power stroke to make it go and three to wear it out still applies. The only difference between now and forty years ago is that by and large machinery does indeed last rather longer than it used to. It also goes better as well.
Martec
Postby Martec » Sat Oct 20, 2012 3:49 pm
Thanks for the information on tappets and not having to adjust them.
In answer to one of my own questions 'How to bleed the clutch slave cylinder',
On 2000MY getrag boxes there is a 2" square rubber seal on the drivers side of the bellhousing. Remove this and a 1.5" bleed nipple can be seen, with care this can be slackened for bleeding. with luck I can borrow a foot from a grandchild tomorrow to replace the brake and clutch fluid. A clip on lid seems to put pressure bleed out of the window.
Spent the last few days removing rust from 4 wheel well brake pipes, some areas in the rear wheel wells and the rear subframe, rust treated, primed and Dinitrol underbody wax to them so hope that will delay corrosion for my stewardship of the car.
Looking forward to coil and plug replacement to get rid of the misfires............I hope.
