Can i replace the bolts that hold the frames to the bulkhead with stainless steel ?. Or is this not advisable.
Thank You.
Front Frame Bolts
Re: Front Frame Bolts
Hello Justin,
stainless steel is not usually recommended for stressed application on a car. I don't know what specification bolts should be used but I would imagine quite a high tensile strength. I use Copaslip on fasteners so that removal in the future is not a problem.
