XType 2001 3.0L AWD rear reluctor ring.
xjscharlie
Hello Folks, Had to install a new rear reluctor ring for ABS and found that the ring i purchased which was listed as compatible was too large. Ring i/d=81.70 shaft o/d 80.76. So it just slides over. Has anyone encountered this issue and hopefully resolved it? What i need is a smaller ring of course. Thanx in anticipation. Charlie.
Re: XType 2001 3.0L AWD rear reluctor ring.
Hi Charlie
I haven't much more guidance beyond that in our exchanges on this topic in the Brake Section back in August.
If it was me I'd probably try to put the ring on the shaft and place about six 0.5 mm shims equi-spaced around the circumference to hold it neatly, but not so tightly as to distort the ring, then apply a good epoxy adhesive all round to hold everything permanently, taking care not to block any of the square holes in the ring.
When fitting the sensor, use a depth gauge to ensure it's not going to foul the new ring assembly. Shim it back if necessary.
Of course you could try another ring; they're quite cheap and another might fit better.
Good luck whatever you try
Edit note
Thinking more about this, rather than six individual shims, a strip of 0.5 mm wrapped right around the shaft would probably still allow the reluctor ring to be pressed on. After a dry run, epoxy adhesive in all the appropriate places should hold it all together.
Edit note
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
2024 XE 300 Sport
xjscharlie
Thanx for the prompt response. I looked for another ring but they all have i/d = 82mm. My shaft o/d is 80.76mm so thort i would raise the issue as i cant be the only one with this problem. There probably is another ring with an i/d of 80mm possibly for another make of car but i dont have the time to research that. Actually i had already cut and prepared a steel strip to wrap around the shaft so will continue with that~hopefully i can effect an interference fit. Regards. Charlie.
Hi Charlie,
Let us all know how you get on.
2003 X350 XJR - daily driver
Past vehicles:
Past vehicles:
