My Series 2 E Type has one fitted but it doesn't work
The sensor is pushed through the fins of the radiator core. The whole lot is encapsulated so it's impossible to put a meter on the connections. I have power at the main fan input terminals. If I connect the green wire to 12v nothing happens (with the ignition on) although this is meant to be the manual override.
Any views would be appreciated.
Roger McEwen
