V12 Coolant
simonzobrien309
I have owned my V12 E Type for almost 2 years now and am aware that the older coolants are recommended for replacement after this time. Is it still recommended that Bluecol or similar Ethyl Glycol products are used? Thank you.
Re: V12 Coolant
The answer is 'yes'. Modern red/pink antifreeze materials do not mix well with older ethylene glycol antifreezes. Mixing causes gels to form and these can block radiators and cause hot spots. Stick with Bluecol or similar ethylene glycol antifreezes to avoid these problems. Mike.
Re: V12 Coolant
I think Mike intended to say "The answer is 'yes'. Modern red/pink antifreeze materials do NOT mix well with older ethylene glycol antifreezes."
Stick with the recommendation.
Jim Mann
Jim Mann
Jim Mann
Banchory
Banchory
Re: V12 Coolant
Tks Jim,
Edited on Mike's behalf
