Engine lumpy when going up hills
Moderators:iRS, Art1012
jaglover842
Postby jaglover842 » Mon Apr 17, 2017 10:10 pm
Hi there,
The Series 2 4.2 roadster is loving the open roads and country lanes of Worcestershire.
However, when I start going up hills, the engine seems to miss a few beats and feels 'lumpy'.
I am suspecting a problem with fuel feed (gravity effects).
Does anyone have any helpful advice on the problem?
Dan
1964 Mk2 3.8
1970 E-type Roadster 4.2
1979 XJS 5.3
1996 XK8 Coupe (Built 13th June 96, used as Press Car)
2010 XKR Convertible
BrianG
Re: Engine lumpy when going up hills
Postby BrianG » Tue Apr 18, 2017 9:30 am
I am not an E type owner but have experienced a similar problem with certain motorcycles in the past. Have you checked the float bowls for water collecting at the bottom? It's worth draining them out to be sure; water from condensation can collect in the fuel tank and then finds its way to the bottom of the float bowls, partially displacing the normal amount of petrol. When going up hill you get an intermittent mix of petrol and water as it sloshes around.
1969 Triumph Daytona rider
Previous XJs:
X300 3.2 in Spruce / Barley
