rev counter types
frogeyeman
Does any one know the difference between RVI and RVC rev counters?Having problems with mine.My present and previous classic cars have always had cable drive rev counters.(Reliable!!).The present one in car is RVI,and Lumenition ignition is fitted.car is series 2 4.2 litre.
Re: rev counter types
Hello Frogeyeman,
The RVI has a single coil of wire on the back to which the ignition feed from the switch connects and the feed to the ignition coil. Have a look at this link for more details:- http://www.newtronic.co.uk/new/support/ ... sTacho.pdf
The RVI is an earlier type so finding a suitable 6 cylinder Jaguar tachometer should be possible?
Or as I said in another post, go back to points?
frogeyeman
Thanks for the reply will try and source a different tacho of the RVC type.Hello Frogeyeman,
