Hello All
I hope that you are coping in the current circumstances
I have a problem with the ignition switch on my 1972 E Type, as follows :;;>
When I turn the ignition key to the pre start position, it should activate the fuel pump..
Unfortunately, there is no response from the pump.
I have turned the key to the pre start position , discovered that there is no power through the white cable, from the switch to the fuel pump.
I can find no information on replacing the switch in my workshop manual, and I am reluctant to tamper with it, without further information.
Can anyone please advise me on this problem ?
Any assistance that you offer will be very much appreciated
Thanks a lot, and stay safe
R Whittington
Mob no. 07853234218
Ignition/starter switch
- greensimonc
Re: Ignition/starter switch
Hi Richard,
An obvious question first - have you checked your battery? Even my modern e pace is giving me a “low battery” warning from relative lack of use.
Just a first thought.
Simon.
Simon.
'66 E Type Series 1, 4.2l 2+2 Auto
MY23 E Pace P300e R Dynamic SE AWD PHEV
Tiger Cat E1
gone and much missed:
'63 reg XF Sportbrake 3.0 v6 Diesel S Premium Luxury
Tiger Cat E1
richard.whittington
Hello Simon
Thanks for your reply, and yes, the battery is fully charged.
Today I removed the starter switch, and found that input to the switch was o.k. But that there was no power from the switch to the pump.
I am now in the process of finding the reason for the lack of power to the pump.
Happy Days
R Whittington
Happy Days
R Whittington
