Hi chaps,
I've referred my problem to Ken Jenkins but whilst I'm awaiting his reply I'm sure he wouldn't mind me opening it up to the assembled gathering to see if someone has a suggestion or two....
I have a 1966 series 1, 2+2 auto, 4.2l which this morning is "dead"! I switched on the ignition, dash lights came on, I heard the fuel pump tick over, then pressed the starter button. There was the faintest of noises from the starter and then nothing. It felt to me like a fuse went, but I can't locate one for the ignition?
Although the interior light comes on when the door is open, the headlights or indicators do not work, and the interior light dims when I try anything else as if there's a drain.
The position now is that when I turn the ignition key, I get the choke light and hand brake indicator come on as usual. When I press the starter button, I can hear a click behind the glove box on the extreme left of the dash, which I assume is a relay? The starter does not function at all, the choke light and hand brake indicator dim, then there's a pause before I hear another click and they go back to their original brightness.
Hmmmm. Earth problem? Or as the starter motor tried the slightest of turns, is that the likely villain?
Ken suggested the buz bar connections, but they all looked ok. I cleaned them anyway but no difference.
Any suggestions gratefully received!
Cheers, Simon.
Electrical coma!
- greensimonc
'66 E Type Series 1, 4.2l 2+2 Auto
MY23 E Pace P300e R Dynamic SE AWD PHEV
Tiger Cat E1
gone and much missed:
'63 reg XF Sportbrake 3.0 v6 Diesel S Premium Luxury
Tiger Cat E1
Re: Electrical coma!
Simon, What you describe sounds just like a dead battery to me !
- greensimonc
Hello mate, yes now you mention it it does! The odd thing is that the fuel pump ticked away as usual first of all......can putting a load like the starter motor on the battery see it off instantly? I keep it on a trickle charger which reflects that it is just maintaining, but if the battery has expired I guess it could charge away to no effect?!
Cheers, Simon.
Cheers, Simon.
Tiger Cat E1
Tiger Cat E1
Simon,
A sixty watt bulb on a 12volt system = 5 amps
A starter motor is jolly near a dead short.
Batteries are classified by their CCC Cold Cranking Capacity and 450 Amps seems to ring a bell.
So you can see why the little things still work
Can you not drop in a spare Battery and try again?
Have you got a hydrometer to check the specific gravity
- greensimonc
Not a hydrometer, but I have got a volt meter.....I should have tested it first but gloomily assumed it was something more serious. Which of course it may turn out to be....!
Cheers for the advice, S.
Tiger Cat E1
Tiger Cat E1
Some jump leads will take you nearer an answer. If you need a new battery, which sounds likely, try an Optima Red Top. America's best. Do you know that NO batteries are now made in England?The Optima is an Absorbed Glass Mat (AGM) type which is completely maintenance-free. There is an informative website if you want a revealing read.
1994 Coupe AJ6 engine
Simon,
I suspect you may have resolved this, but if not my guess would be loose terminals at the battery.
Roger
Roger
- greensimonc
Hi guys, thanks for the responses! I can't try jump leads without removing the battery from my daily driver as the car is up a narrow drive in a single garage..... The connections are all sound as I spent a good deal of yesterday afternoon undoing everything and wirebrushing and sanding them all sparkling clean.
However, I have a small 12v compressor which I know works, and attaching it to the E's battery has no effect so it does look like the culprit. I'm still surprised it gave up so suddenly, but have learnt a lesson......always think of the simple things first, after all if my PC didn't work I would first look to see if it was plugged in!
Thanks for the tip about the Optima Red Top, I shall investigate!
Cheers all, Simon.
Cheers all, Simon.
Tiger Cat E1
Tiger Cat E1
If you do decide to .treat your car to an Optima Redtop battery, treat it also to a charger which will keep it conditioned. C-Tek do a good one which is available from the Club shop, (Annie will sort you out), or Optima seem to be making one themselves but not shown as for 240V yet on their site last time I looked.
- greensimonc
Hi Paul and all,
Just to conclude this saga, Ken Jenkins recommended Manbat as the place to go, but I discovered they don't deliver and are nowhere near me! However, they are really helpful people.
I asked them all about Optima, but speaking to their guru, he said the ideal battery for me was a Varta, Silver Dynamic D21. As they couldn't deliver he recommended Tayna batteries, http://www.tayna.co.uk
This gives 600 CCA as opposed to my old battery which was 390! Not as much as a Red Top, but said to be perfectly adequate. Also, not that I usually scrimp on anything to do with the car, but the Optima was £124 plus vat, plus delivery (from Optima themselves) whereas the Varta, was £56 all up, delivered by courier next day (today!).
So, hope I've done the right thing. Time will tell if it's good value, but certainly great service! And I now have a ticking fuel pump, lights and ignition, and a running car again!
I already have a trickle charger, which I suppose is one reason I didn't suspect a catastrophic battery failure in the first place.....sort of expect it to keep it in good condition, but then I inherited the battery with the car so no idea what had happened to it before.
Cheers and thanks for all the replies, Simon.
Tiger Cat E1
Tiger Cat E1
Well done,
Varta is part of BMW and is a good quality product
Simon, Would be interested in what your 'guru' had to say about Optima. They are expensive I know but the unique construction appealed to me, and being American is another plus point as they seem to have no interest at all in things which are not reliable. ( Sadly that's why there is a 'Lumps' website telling you how to put Chevrolet V8's into Jaguars, but that is another story. )
My car gets many short journeys and isn`t really used enough to preserve good battery life.
i`ve struggled with the Halfords brand and sadly have to report I had a completely dead one inside a year.
I can`t tolerate that sort of unreliability and have transferred my allegiance to the Varta Blue brand which for my S-type cost £128 trade.
Batteries tend to give up in the winter when temperatures are low and engines more difficult to crank. That soon finds out whether the battery is up to the job. Hopefully the new Varta will stand the strain.
As far as battery drain is concerned on our Jaguars, the security systems on our cars do take current and cause terminal voltage to drop over a period of non use. As I understand it, double locking the car helps to reduce battery drain when the car is not in use. Single locking does not fully shut down the maximum number of electronic services.
- greensimonc
Hi Mike,
Thankfully my car's security extends to putting a small key in the lock and turning it towards the rear!
Paul - the guy at Manbat was not dissing the Optima as such, just that when I explained the car and its electrical needs, he recommended the Varta...... I hope I have done the right thing and that it's several years before I find out!
S.
S.
Tiger Cat E1
Tiger Cat E1
Hi Simon,
I'm pleased your battery woes are over but a couple of points you may like to think about.
When you have a bit of spare time, clip your volt meter across your posh new battery and see the following:-
With the ignition off, take a note of the battery voltage - can't remember about 12.8v
Switch the ignition on and the voltage will remain above12v, so that shows a load of 2/5ths of naff all
Now hit the starter button and watch the voltage drop like a stone down to 8v whilst the engine is cranking. Now the battery is really working for a living. As soon as you release the starter button the voltage will recover to 12. something volts.
Later cars with an ignition key used to crank the engine,had two feeds to the coil. Whilst the engine was running the feed passed through a ballast resister reducing the voltage to 8v which fed an 8v coil. During the engine cranking phase the ballast resister was bi- passed allowing 12v to go to the coil. As you may have discovered battery voltage drops to 8v during the cranking phase so by fitting an 8v coil it is supposed to assist in the starting process.
Going to those lengths clearly demonstrates the loads put upon the battery. A final thought is with regard to the loads during the winter months. Battery voltage drops X for every one degree below freezing. Sorry can't remember what X is. Someone will remind us.
There we go, just a couple thoughts while passing.
Oldtimer
Oldtimer
