S3 Door drain guards
Moderators:iRS, Art1012
eb96pfh
Postby eb96pfh » Mon Nov 03, 2014 11:04 am
Does anyone know whether it is possible to buy the door drain guards that should fit at the bottom of the doors? They are there to prevent water leaking into the car when it rains I gather, a problem I suffer with my S3, which doesn't seem to have these.
I've only seen a rather blurred picture, so not entirely sure what these drain guards are supposed to look like (and can't find another car with them fitted), so does anyone have a good picture or any information as to how I could make these if they aren't available to purchase?
Many thanks
Peter
raysearles
Re: S3 Door drain guards
Postby raysearles » Thu Nov 06, 2014 11:46 pm
I don't know the answer but if you find out please post it here as I have the same problem!
Ray
JEC Events Chairman
1999 XKR Convertible (K8)
eb96pfh
Postby eb96pfh » Mon Nov 10, 2014 10:44 am
Found the answer at last and posting in case this helps. Seems I was confused by the simplest thing which is what these are called. Having looked through an old parts catalogue it turns out these are called door drain shrouds, and then asking SNG Barratt produced an answer that these are available:
http://www.sngbarratt.com/ProductDetail ... d1182aed49
Part No. BD20878 and available for £8.75 each, so I've got 4 and will see how easy they are to fit.
Pete
