I think this may well be known but if not then it could help save someone money. A cheap upgrade to series 1 brakes are Volvo 244 front calipers with a reduced diameter disc, about 6 mm from memory. There are 2 options on the caliper, either cross drill internally and blank off 1 of the dual circuit feeds or fit with 2 feed pipes.
For series 2 brakes I had made uprated stub axles which allowed the use of 4 pot XJ calipers and ventilated discs, see www.etypepat.f-snet.com and look at the series 2 2+2 page.
Brake Upgrades
On the other hand you could go to www.jcna.com/library/tech/tech0031b.pdf where you will find a write up I did around 2004.
Dave
Dave
stuarthardy
Hi Franck
I think you should be able to fit 4 pot calipers to your E-Type. Why not give Ken Jenkins a call and he'll talk you through it? He might even be able to supply the necessary parts you will need because he has a large stock pile of used Jaguar parts.
His contact details are in the club magazine.
Stuart
Stuart
Stuart
1962 E-Type FHC
1969 420 Daimler Sovereign
1994 X300 XJR
1962 E-Type FHC
1994 X300 XJR
