Vacuum servo - air leak across diaphragm
Moderators:iRS, Art1012
devinaandethel
Postby devinaandethel » Sun Sep 17, 2023 10:47 am
Car Series 2, 2+2, 1969 LHD.
I noted recently that just after the engine was switched off the brake vacuum dropped quite quickly. Eventually I found three leaks, the check valve, the joint between the reaction valve and the master cylinder body and the rubber pipe to the brake servo. To aid finding the leaks I took the components off the car; using a 12v small vacuum pump to check the servo for leaks I connected the pump to both sides of the pneumatic diaphragm. A good vacuum was achieved and when the pump was switched off the vacuum remained steady, no drop.
However when I connected the pump to just the front side of the diaphragm (i.e. nearest to the hydraulic cylinder) the pump was unable to establish any vacuum UNTIL I blocked the pipe to the rear volume. So clearly there is a "leak" across the diaphragm, checking the latter visually I am certain that it is not punctured, so conclude that the "leak" is at the centre, where the rubber fits over a boss in the plastic support.
I would have thought that for the servo to operate efficiently there ought not to be any air flow between the 2 pneumatic chambers.
So my questions are thus, is this normal, has any other member had a similar experience and how does one cure the leak?
