Gearbox tail shaft housing
Posted: Mon Jun 11, 2018 6:58 pm
by colingray
I am looking for a series 3 manual gearbox tail shaft housing, mine looks to have been welded in it former life and leaks oil all over the exhaust.
I had been hoping it was the rear oil seal and also replaced the speedo drive seal as an added precaution.
Hopefully someone who has done a five speed conversion will be able to help?
Colin Gray
Re: Gearbox tail shaft housing
Posted: Sun Jul 15, 2018 10:28 pm
by colingray
I have this all sorted now and had it repaired by removing the tail shaft housing while the gearbox was in place by following the procedure elsewhere on this forum (The E type forum). I took the housing and had the seal opening welded as the previous welder had made such a terrible job of it that the oil was leaking past the outer edge of the seal. It is all back in and after approximately 50 mile seems to be fine. :D
Posted: Mon Jul 16, 2018 9:56 am
by PPV
That is good news. Did you use a specialist welder you would recommend?
Posted: Sun Sep 23, 2018 6:00 pm
by colingray
Hi, I used a mate who I have know for years, he tunes racing MZ motorcycles and does lots of aluminium welding on them. I was hoping for a casing but thought I would ask him if he would have a go at it which, he did for me and made a cracking job. He only wanted a drink £20 :roll: However I dropped him £60 as he was well worth it. I am sure there are some decent aluminium welders around the UK I just got lucky having a friend that does it.
