Throttle Linkage
Moderators:iRS, Art1012
keith140c
Throttle Linkage
Postby keith140c » Tue Feb 09, 2010 4:13 pm
I am trying to assemble the throttle linkage for my 4.2 litre S1 FHC.
The linkage had been modified for 1 3/4" SU, so now I've fitted the correct 2" type something is not correct as the accelerator pedal does not move the throtle butterfly fully open.
What I would like is a picture/diagram of the linkage while the pedal is at rest, so I know the relative start positions of the "L" shaped pivot levers.
Thank you
Keith Brown
TonyB
Postby TonyB » Mon Mar 29, 2010 7:07 pm
The position of the first bellcrank is set by the stop. The others move through right angles to the rods at around mid-travel. I think you need to see someone's car to measure if the carb levers are right length.
