stainless steel exhaust manifold
Moderators:iRS, Art1012
glenmere15
Postby glenmere15 » Thu Aug 06, 2009 8:55 am
can anybody tell me of the advantages of these i am led to believe that they will help keep the cabin a bit cooler is this correct
thanks
PoB
SS Manifold
Postby PoB » Fri Aug 07, 2009 5:01 pm
Lowering cabin temperature has not been my experience after fitting SS Manifolds. They are fitted to improve performance, however, unless designed and fitted with a number of other changes/enhancements they could lower BHP. The standard manifolds are well suited to a standard engine.
The other reason to fit them of course is appearance. Look on:
www.etypepat.f-snet.com the click on the Lightweight Replica section for a good example. I had these made by Haywood and Scott and what you see is exactly how they came, fitted with no problems.
Best of luck
Pat
