E type V12 oil pressure 'build time'
Moderators:iRS, Art1012
timhenson
Postby timhenson » Sun Jan 09, 2022 5:25 pm
Does anyone have any experience on how long the oil pressure takes to 'build up' after starting? On my car it seams more than a few seconds particulary if the car has stood for a few weeks. As I write this topic I am thinking I have not actually timed it, but it just seams long. I plan to time it incase my mind is playing tricks, but meantime are there any thoughts?
The oil pressure cold is 75/80psi. Hot running 50/60psi. Hot tick over 38/40psi.
Original engine, never rebuilt, 30,000 miles, using 20/50 oil.
Thanks inadvance.
Kind regards Tim
Tim Henson
Jaguar 1971 series 3 E type V12.
Rolls Royce 1933 20/25.
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
timhenson
Re: E type V12 oil pressure 'build time'
Postby timhenson » Sun Jan 09, 2022 5:43 pm
Further to my above topic meant to say as well where my mind is going: is there some sort of anti drain valve to keep the pump full?
Kind regards Tim.
Tim Henson
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
piman
Postby piman » Sun Jan 16, 2022 11:33 am
Hello Tim,
not really my area of experience howeve I note that you have not had a reply.
Oil pumps do not need an anti drain valve as they are capable of sucking from lower than the pump itself, this is due to the pump design, sometimes described as positive displacement.
That characteristic is similar to the Triumph six cylinder engines due to the design of the oil filter, where the oil drained from the filter back to the sump and oil pressure didn't develope until the filter re filled. Looking on the Martin Robey website it seems to illustrate a horizontal paper element oil cleaner much like the Triumph design. I would have thought that being a much more modern engine there would be something to stop the filter housing emptying? It certainly looks a much more complicated design than the Triumph in which the filter canister bolted directly to the block.
You might like to have a look in that area?
timhenson
Postby timhenson » Sun Jan 16, 2022 12:00 pm
Thanks Alec. That gives me a good starting point I will have a study.
Kind regards
Tim
Tim Henson
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
timhenson
Postby timhenson » Tue Dec 05, 2023 9:16 pm
Thought I would add to my first post all be it now 18 months old!
Basically, I have now timed it. The results being it takes from cold after not having run for many weeks, 10 seconds once the car fires to build to 50psi. It then goes on to idle at 85psi cold. And idle hot at 50psi.
What do people think of the 10 seconds. It's as if the oil drains out of somewhere over time.
Thanks and kind regards Tim
Tim Henson
Jaguar 2005 XK8.
Jaguar 2003 XJ8.
