can anybody tell me of the advantages of these i am led to believe that they will help keep the cabin a bit cooler is this correct
thanks
stainless steel exhaust manifold
SS Manifold
Lowering cabin temperature has not been my experience after fitting SS Manifolds. They are fitted to improve performance, however, unless designed and fitted with a number of other changes/enhancements they could lower BHP. The standard manifolds are well suited to a standard engine.
The other reason to fit them of course is appearance. Look on:
www.etypepat.f-snet.com the click on the Lightweight Replica section for a good example. I had these made by Haywood and Scott and what you see is exactly how they came, fitted with no problems.
Best of luck
Pat
Best of luck
Pat
