Rear Gearbox Seal
Posted: Sat May 24, 2014 7:09 pm
by MrNpw
Does anyone know if you can access the gearbox end plate from inside a 2+2 interior ??
I know that the fhc has an access hole inside under the centre console and you can see the prop shaft bolts, with the 2+2 i am wondering if this is still possible ?i don't want to pull the interior apart if not.
I am attempting to replace the rear gearbox seal without removing the engine or box, i know it is possible on FHC and OTS.
Re: Rear Gearbox Seal
Posted: Mon Jun 02, 2014 9:29 pm
by chris.g
Fairly sure that you can access the prop shaft through an access plate
