Do The Team Think
Moderators:iRS, Art1012
e600
Do The Team Think
Postby e600 » Mon Nov 28, 2011 1:17 pm
As a possible means of getting some traction in the E Type BB.
Whats the view of the next generation taking over the reins for home restoration of current and recent modern Jaguars. My belief is the E Type, XJ Series 3 and possibly the XJS were the last real home restoration candidates.
Moving into the XJ40 Series I don't believe is a viable home restorers car, and certainly not in 10 or 15 years time. Anything after the XJ40 is even more unlikley to be restored, not because of the mechanicals, nuts and bolts are after all nuts and bolts, similarly welding is welding (although aluminium cars pose a different level of skill). The real issue will be the electronic modules, ecu's, digital displays and even harnesses. If you take an XK8 and there are some examples about that can be bought for as little as £3k, in several years time when access to cheap spares has passed (have you tried to get any XK engine bits from your local breaker in the last couple of years?) where would one go to rectify an alarm module or digital display or engine/gearbox ecu. These won't be fixable by the part time home restorer and I don't think companies will gear up to produce spares
I think we are living in the twighlight of the home restorers day. Home respays are almost non existant due to H&S legislation and I can see the day when an individual won't be allowed to buy paint for home spray use. Similarly home storage of gas cylinders for welding purposes will be a no no.
This might be overstating the case, but I don't think so....what does the team think? :?
stuarthardy
Re: Do The Team Think
Postby stuarthardy » Mon Nov 28, 2011 4:25 pm
Its hard to disagree with you as I think your analysis is a good one.
However, I would never dismiss the ingenuity of the bloke in his shed, he has given us many great inventions and solution to thorny questions. Necessity being the mother of invention (or was that Frank Zappa).
Then again, we'll all soon be whispering along in shared ownership electric trolleys because, let's face it, the only place we'll be allowed to go will be the Supermarket to buy only products approved by the Health & Safety nazis.
Am I the only one who thinks I am being manipulated into feeling guilty for my inquisitiveness and passion for things mechanical?
Oh dear, another rant. Better increase the dosage, nurse.
Stuart
1962 E-Type FHC
1969 420 Daimler Sovereign
1994 X300 XJR
