Seeking advice regarding suitable trolley jack for home use , preferably lightweight .
Trolley Jacks
To jack the rear of the car high enough to remove the rear subframe you need a lift of about 450mm. To do this in one move means using a big (and heavy) trolley jack. Mine will also go under the picture frame to lift the front using the hardwood spreader. I use a small cheap trolley jack for every other job.
Tony
Tony
