CD changer fitting - is new boot trim needed?
charlier6790
Postby charlier6790 » Tue May 06, 2014 7:04 am
I've had a CD changer fitted in the boot of my 2003 Sport saloon. But that means that the N/S boot trim no longer fits. Is it possible to cut the existing trim (and is there a template available) or must I buy a new trim section designed for a car fitted with a changer?
robv12
Re: CD changer fitting - is new boot trim needed?
Postby robv12 » Tue May 06, 2014 9:24 am
not sure about saloons, but I have done this job twice on an estate, you need the correct trim and the correct boot floor moulding (I in fact cut the old one to shape)
You may need to have the car on diagnostics to tell it that a CD changer is fitted, not sure on a 2003 car, but on my 2004 and 2005 cars I had to do just that procedure
Hope this helps a bit
Rob
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
