What's the code I ask you say ?. Don't have a clue and neither do those friendly folks at Jaguar either but not all is lost as it's a simple pattern that is instantly recognisable.
Looking inside your key, does your key look like a " Y " with the fourth detent sitting equally in the upper centre between the two forks of the Y. This fourth detent and the one on the bottom leg is directly inline through the centre. Or for those of you who are children of the 70's think of the CND symbol. It's the same.
If you think you have a matching key then please message me with your location and we can even exchange pictures to see if I think it will fit and you are within a reasonable distance.Then I can pop round, use your socket to get my wheelnuts off and replace them with after market ones on the spot. Might be even worth a pint or two !.
Regards and Thanks in Advance to anybody who can help me.
Henry
Tel: 0791 916 0925
