Front door puddle lights
Posted: Sun Oct 23, 2011 8:21 pm
by steveisleofwight
Hi everyone
I have a 2005 (EU4 emmision spec) 2.0 diesel Classic.
By way of 'upping the spec' of this car I am adding some of the fixtures and fittings of the higher spec cars. I have already replaced the centre console cubby box by the more attractive flip-up ashtray arrangement.
I am now contemplating changing the inert red lenses in the front doors with working puddle lamps. Does anyone know if the wiring is already in place inside the doors on this spec. car for the puddle lights before I take the door cards off to investigate further?
Cheers, Steve Cocks
Re: Front door puddle lights
Posted: Wed Sep 24, 2014 8:36 am
by TheWhiteSuit
Hi Steve
I see this is an old post. Did you ever do this upgrade?
I contemplated doing a similar thing after I was told the red lenses had no "live" function but have never progressed it.
Posted: Wed Sep 24, 2014 8:41 am
by Brakebuster
i have researched this , and there is no existing wiring to make the puddle light work
you will need to run a wire through the door , and through the hinge loom to the existing intiror lighting loom to make it work
too much work in my opinion
BB :roll:
Posted: Wed Sep 24, 2014 9:44 pm
by TheWhiteSuit
Hi BB
I have done no research myself but as you have do you think this might this work?
I assume there must be an ignition switched live feed in the door for the window motors so if one used a suitably fused tap off that through say a reed relay to an LED light it would save running any new wires with negligible additional load. The control magnet might simply glue to the door frame.
I suppose it would be better to use the unswitched door lock feed because of the availability but I wonder if the security system might detect it and treat it as tampering and trigger. Guess you could load it with a resistor first and see if it goes off before fitting the lights etc.
I think you could use a Hall effect switch instead of the reed relay rig but I don't think the complication is worth it unless you wanted to add timers or light sensing control in the circuit, even then the reed may be the best.
Anyway I am no electronics engineer and I find reed switches just work.
Let me know (anyone) if it is a plan?
Posted: Thu Oct 02, 2014 6:01 pm
by steveisleofwight
Hi All
Thanks for your input. No I never bothered with the upgrade, it was only going to be done if it was a 'plug-in and go' option! Like BB said, too much work otherwise!
Car up for sale now too!
Thanks again, Steve
