2001 3.0L Rear Electric Window Operation
xjscharlie
Postby xjscharlie » Thu Jul 09, 2020 3:37 pm
Hello Folks,
The rear drivers window on my 2001 3.0L has stuck down. On operating the window from closed it moved down about 1.0 inch at a time by repeatedly operating the switch. Once fully down it would'nt go up. I disconnected the plug on the window motor and on pressing the switch to go up it went up 1.0 inch and stopped but would'nt go up further despite operating the switch. When pressing the switch to go down it went down again but would not come up at all. On disconnecting the plug and retrying it went up again 1.0 inch but no further as before and again on pressing the switch down it went down and would'nt come up again. I tried the procedure again and it repeated. Have followed the procedures as detailed in the handbook but nothing works.
Could anyone help? Any advice welcome. Tanx in anticipation. Charlie.
xjscharlie
Re: 2001 3.0L Rear Electric Window Operation
Postby xjscharlie » Thu Jul 09, 2020 4:58 pm
Just an additional question~does anyone have a wiring diagram for the electric windows? I have the Haynes manual but there's no diagram there for the windows. Thanx. Regards.
Astromorg
Postby Astromorg » Thu Jul 09, 2020 8:35 pm
I had a similar problem to this on the driver's window and no amount of resetting iaw the handbook made any difference. In the end I disconnected the battery for a couple of minutes, reset the windows and all was well.
I did experience this problem a couple of other times (I've had 2 X types over 14 years!) and found that just removing the relevant fuses for the affected window did the trick. There are two fuses for each (diagonally arranged in my car) pair of windows. Your hand book should identify the fuses for your model year that are different to mine.
Hopefully either of those two ways will help you out, but let the forum know for future reference and for more help if required.
The whole set of electrical diagrams can be found here http://www.jagrepair.com/Default.htm
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
xjscharlie
Postby xjscharlie » Fri Jul 10, 2020 5:04 pm
Many thanx for the advice & the link. I'll try the fuses then i'm going to change out the motor unit to see what happens. Regards..
