auxiliary cooling fan
phirou
Postby phirou » Mon Aug 23, 2010 1:01 pm
I suspect the auxiliary electric fan of my 92 XJ is not working as it should, or perhaps not working at all. The needle of the temperature gauge used to stays on N even in adverse conditions : getting stuck in traffic on a very hot day for instance (with the A/C on, of course). Recently, I noticed that in these circumstances, the needle went further right (never reaching the red zone thoug).
- Should the fan be running as soon as the A/C is on, or only when the coolant has reached a given temperature ?
- Is there a way to test it ?
First, I think I should check the fuse. Does anyone know where it's located ?
xtypebod
Re: auxiliary cooling fan
Postby xtypebod » Tue Aug 24, 2010 6:09 pm
assuming u are refering to xj please,post to xj. thanks xtypebod
robv12
Postby robv12 » Wed Aug 25, 2010 7:01 pm
i have picked up on this and am awaiting more details on the car, we can go from there
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
phirou
Postby phirou » Wed Aug 25, 2010 10:30 pm
Hi Rob
I am afraid we are discussing in the wrong forum. I have posted the same message in the XJ forum. My car is a 92 XJ 3.2 Sovereign : one belt driven fan plus an auxiliary electric fan (As you know, there are 2 electric fans from MY 93). I wonder if the auxiliary fan is designed to operate when the A/C is on, or at a given temperature, and if there is a way to test it.
By the way, I think you are doing a great job on the forum. XJ 40's are really worth preserving. It is a shame these cars are worth so little that many owners think they are not worth repairing. I can't think of any other car as my daily transport. Reliable, comparatively cheap to run, roomy, comfortable. The style was once considered as "too modern", now it is almost a classic. I suspect modern Jaguars do not age so well, and older models may be wonderful, but are not suited to everyday use.
With the 3.2 engine, an XJ40 is a rather sedate car, but do we need more power considering the ubiquity of speed cameras ?
robv12
Postby robv12 » Thu Aug 26, 2010 10:07 am
see my reply in XJ forum
