The rear glass has stopped opening on my 2005 2.5 Sport estate. It went through a spate of opening for no reason (unless the central locking was locked), then it has stopped opening at all, so now I cannot open the rear glass.
I've no idea where to start - it must be an electrical fault somewhere, but where? Could this be a DIY job or do I need to go to a dealer / specialist? Has anyone else had the same problem?
Rear tailgate glass release
Re: Rear tailgate glass release
I had same problem on 2007 model took to the dealer new switch 5 min fix. no idea of cost as under warranty seems to be a common problem according to dealer should not be difficult as it took him 5 min.
hope this hlps
Larryd
hope this hlps
Larryd
Had the same issue, the tailgate glass on the X-type estate kept popping open when I started the engine, I had to shut it each time then it stopped opening altogether using the button.
Initially I suspected the latch and subsequently went about sourcing the same from the local Jaguar main stealer, during a conversation with the parts guy, explaining the problem he advised that the fault might not be the latch but the liftgate window glass release switch (part no C2S 50868, cost £68.60 incl VAT), a known fault due to water ingress. Took about 30 minutes to replace, fairly easy job covered on jaguartechinfo.com (GTR) article 76.19.59.60.
Frenchdavee
In your reply to the above problem, you referred to "jaguartechinfo.com " what is this link (tried it but failed to find anything), as it seems a good source of technical info. Thanks Dave
TheEngineer
Just completed repair on my 2009 X type estate, (that I bought new).
Not dealt with under guarantee, (I didn't bother to ask, the dealer, Watford Jaguar, had already spent £12,000 defending a claim regarding my claim of £5,000 regarding complaints when I felt I had largely to concede - I couldn't risk having to pay that kind of amount!). I found, as have others, that water gets into the rather silly switch, causing nuisance operation then failure. I removed the original switch and fitted a simple small push button switch that I had removed from a modest hi-fi unit, reassembled and all is now OK. Time taken about an hour. Cost about 3p. I sealed the assembly with grease, not glue, so hopefully no more water can get in but if it does it will be easy to strip.
This was a very stupidly constructed assembly - how many more such traps are there for me to find apart from the shoddy plastic bumpers and sills, dubious thermostat, poor stereo etc?
