Water leaks
davidc
Water leaks
Postby davidc » Wed Nov 12, 2008 8:06 pm
Has anyone experienced water leaks on this model. I have a car which is plagued and I cannot find them! 06 registered. Seems to be comimg in on the nearside as carpets soaking and then running through to back. Grateful for any suggestions
David
jagtech
Postby jagtech » Sat Jan 03, 2009 9:12 pm
Water mostly leaks in past the pollen filter housing and appears on the carpet directly below the glovebox the other source is past the door seals from inside the door casing
