Hand Brake jamming on
Posted: Sun Mar 08, 2009 3:28 pm
by JamesRS1600i
My drivers side handbrake keeps jamming 'on'. Temporarily I can release this by moving getting under the car and releasing the handbrake at the caliper. I've squirted some WD40 down the hand brake cable (from the caliper side) and this seems to be working, but I'm guessing this would be a temporary fix. Is this a common problem? I'll have to replace the handbrake cable if it happens again (no pattern parts available, have to get direct from Jaguar). Interestingly, both times it happened are when there is salt on the roads. Any connection?
Any comments most welcome.
Posted: Fri Mar 26, 2010 12:34 am
by Telsmoneypit
I think you've answered your own question James. If WD40 "temporarily" cures the problem, I would suggest that proper lubrication on the handbrake cables/calipers would provide a permanent solution.
As the X-Type shares its discs and pads with the ford 'Mundane' it's highly likely that the handbrake cables are also a Ford part....Worth checking before opening wallet and giving all your money to Jaguar only to receive a blue oval in a green box....
Been there done it.
:roll:
Posted: Fri Mar 26, 2010 2:09 am
by BuckMR2
Been there done it.
:roll:
Yes the X type and Mondeo Mk3 share around 20% of its parts
But surely for the cable to be the same the distance from the handbrake to the caliper and the route it takes around the different floorpan to the Mondeo would need to be the same which they arent?
Re: Hand Brake jamming on
Posted: Sat Jun 09, 2012 2:50 pm
by jeff1954
I thought the X Type shares its floor pan with the Mondeo?
Jeff.
Posted: Mon Jun 25, 2012 10:56 pm
by gwj
Its a shortened Mondeo floorpan, IIRC by around 2.5"
G
Posted: Thu Jul 05, 2012 9:40 am
by PaulRidley
Just an addition to this topic - the handbrake cables are a notorious weak point on these cars and very expensive.
We had them done on our D Estate and from memory it was over £200 at Guy Salmon in Oxford...
I'm sure it could have been done cheaper elsewhere, but if it says Jaguar on the bonnet it has to say jaguar over the door of the service department :D
