Spongy Brakes 2009 2.2D Turbo
ng4xjs
Postby ng4xjs » Sun Aug 20, 2023 6:56 pm
Brakes on my Wife's 2009 variant feel a tad spongy. No obvious leaks and brakes work perfectly well. Slight drop in brake fluid. My gut feeling is the brake master cylinder (100200 miles). I think I can source a new replacement locally but had not previously appreciated that finding hens teeth was an easier challenge.
I've had a look at what Haynes say. Move header tank, disconnect switch, undo the two brake-pipe connections, the two retaining nuts and then wriggle free, etc.. I do have an easy bleed so was proposing to do using this rather than someone pressing the peddle which I gather can actually create air in the system if not careful. My question is this. Whilst watching an American video the mechanic (not Jag) simply loosely reconnected the two pipes pressurised the reservoir and whilst fluid escaped the connection tightened, one then the second. He went on to say, "job don" but surely still has air in the system?
Unless someone says otherwise I was going to do it the traditional way? Any other tips greatly appreciated. At least then there will be some clean fluid in the system.
Happy days
1994 4.0 XJS AJ16 BRG
2009 2.2 X Type Diesel BRG
2007 4.2 X150 Silver
Dave Eynon
Re: Spongy Brakes 2009 2.2D Turbo
Postby Dave Eynon » Sun Aug 20, 2023 7:49 pm
It helps the process if the master cylinder chamber is primed with fluid, I have had to achieve this by slackening the pipe unions on other models, otherwise it sometimes doesn't self prime. If the traditional method involves pumping the pedal with an assistant then avoid fully depressing the pedal as this can damage the servo. The consequence is the brakes do not fully release and a new servo is required. A small wooden block on the floor helps to avoid this. I bought a vacuum pump to pull the fluid through which worked well.
Dave
Dave E
Gwynedd. N Wales.
X-type 2.5 Estate
XK8 Coupe
XJ 4.2 S1
Daimler 2.5 V8
Astromorg
Postby Astromorg » Mon Aug 21, 2023 9:31 pm
I'll second that advice from Dave :D
X type master cylinders seals can be 'flipped' by over-exuberant use of the brake pedal to bleed the system. An alternative to the vacuum system is the pressure system by Gunson, powered by the spare tyre (If you've got one!) or, with a bit of suitable metal tube to connect it, a tyre pump.
Don't forget to change the brake fluid every couple of years by bleeding the system until all the old fluid is expelled from all four brake calipers.
2005 XK8 4.2-S Coupe
2024 XE 300 Sport
