starter motor problem
Postby Brakebuster » Wed Sep 04, 2013 4:05 pm
this morning the starter motor on my 54 plate 2.1 petrol did not want to turn the engine over :( , in stead it made a horrible grinding noise :shock: ,
last week she failed to start and i thought it was a flat battery , though known to be good i swapped it out and put in a new one i had , and she fired up , but since then she has just ' clicked ' sometimes, but then in the second attempt has fired up :roll:
but this morning, no go :? , i diagnosed it as the solenoid on the starter not throwing forward the starting gear , a little research and found this is becoming more and more of an issue on our cars
remedy is replacement , or as i did a strip and clean of the starter motor :roll:
removal is easy on my engine :) , remove battery and tray , using a 13mm socket remove the two vertical mounting bolts on the starter, and the two connections on the rear once the motor has been twisted round
removal requires a little jiggling around, but it come out easily
on removal i could see the gear was caked in black debris , this was not letting the solenoid do its job , and i could barley move it by hand ,
i used some contact cleaner to remove the dust and gunk , and this started to free up everything , eventually i could freely move the gear wheel and the solenoid throw by hand, and left it to drain , cleaned everything up and reinstalled into the car,
the first turn of the key gave me a ' click ' the second turn and the car fired inot life, possibly just a meshing issue and still a bit raw after the cleanup ,
a new starter from Jag is £130 plus the VAT , so not too bad , especially as its a pop to fit
so for the sake of reliability , i have bought a new unit and will fit it next weekend ,
anyone else had to do this ?
btw, the ' Mondeo ' starter looks very similar, but the mounting bolts are longer as the shoulders are deeper on the ford part , just so you know
oldtimer
Re: starter motor problem
Postby oldtimer » Wed Sep 04, 2013 9:11 pm
Hi BB,
Interesting to read the above. I have read that vehicles fitted with Dual Mass Clutch / Flywheel Assemblies create amounts of black dust that finds its way through to starter motor which in turn effects the starter motor performance. In your case is this a sign of things to come !
I have an S Type which also has a dual mass flywheel so I keep an eye on anything to do with this subject.
Postby Brakebuster » Wed Sep 04, 2013 10:08 pm
yes , its a dual-mass as you describe
apparently the majority of the dust is from the clutch plate friction material , but as you say , its something to look out for ,
i think my car ( which i have had for under a year ) was used for motorway journeys had done 110k , and it now does 3 mile runs as its my wife's car , though the clutch does feel ok for the time being, and no signs of any slippage etc
but for under £2k what should i expect , lol
so far,a reverse switch , a water pump ,an auxiliary belt and pulleys and a battery.........
so cant complain
BB :)
oldtimer
Postby oldtimer » Thu Sep 05, 2013 5:11 pm
BB,
As you say, can't complain
