Scottish highlands jag
Ardelvejag
Postby Ardelvejag » Sat Feb 09, 2019 3:45 pm
Hi all, thank you for letting me join, quick question, will my x type pass an MOT with a leaping cat on the bonnet ( spring loaded ). Cheers all
RichardSEL
Re: Scottish highlands jag
Postby RichardSEL » Sat Feb 09, 2019 7:19 pm
If it came from the factory that way, or is a Jaguar-approved add-on for that model probably OK
If an aftermarket addition, and it seems from your question it probably is, probably not
Probably :?
Postby ptjs1 » Tue Feb 12, 2019 1:57 pm
It didn't come from the factory like that so it's not official. It will depend on how far back from the leading edge of the bonnet it is mounted and more relevantly, what frame of mind you catch the MoT tester!
only1pearson458
leaper
Postby only1pearson458 » Thu May 02, 2019 10:41 pm
Hello,
I have had spring loaded leapers on my last 2 X Types, I checked with the local police, they told me if it passes the mot then it is legal. So 8 years later I have never had a problem. Good luck.
