door locks
my car wont lock with the remote, has any body come across this?
Re: door locks
Yes, I had the same problem a little while ago. I purchased a new battery (From Boots chemist ) much cheaper than Jaguar. The fob is fairly straight forward to dismantle but make sure you insert the new battery immediately after removing the old one, other wise it may lose the memory.
All was well after I changed mine.
Good luck. Chris.
Good luck. Chris.
