I have plenty here, all refurbed with new lasers and loading motors, pm me for prices and details
they are all plug and play, all cars are pre wired
location of unit will depend on year of car, most 300's have them fitted under the rear parcel shelf thus (altough this is a 40)
you will find six pre drilled and tapped holes to mount the brackets to, you will use four depending on the size of the unit thus
this is the smaller and later style unit, there is an earlier one that will also fit and work perfectly
the wiring for these cars will be behind the boot back board on the right hand side, if a cd has never been fitted it will be clipped to the fuel tank, the 8 pin din plug will have a liitle rubber protecter over it, if a cd has been previously fitted the lead will most likely be hanging loose or even poking out from behind the back board
On the last 300's , 97 MY I think, the changer was moved to the left hand side of the boot behind the wheel arch thus
you will need a moulded carpet for this as well, and only the smaller unit as above will fit, this also needs a mounting cage which I have here, this mounts to the boot floor, the wiring for these cars is the same, but will be clipped to the left hand rear whhel arch behind the boot carpet
hope this helps, as i say pm me if you need more help, details or prices
