WANTED security system
sickpete420
Looking for complete security system for my xj40 the type that takes a remote with single button
Re: WANTED security system
https://www.ebay.co.uk/itm/4-Channel-Wi ... 2107712106
Sickpete, i use this module to switch new relays i installed in the in the fuel pump supply and the ignition supply to the coil on my Mk2 There are other modules available on ebay with one and two channels but i use the other two on this version for driving my electric aerial and under bonnet lights.
Not an off the shelf solution but not easy to defeat either. Let me know what you think.
sickpete420
thanks great idea my current alarm (dont think the alarm actually works) does the central locking ok just wanted to use the jag fob even if it means replacing circuit
