auxiliary cooling fan
Posted: Tue Aug 24, 2010 12:11 pm
by phirou
Sorry, my message was posted in the X-type forum.
I suspect the auxiliary electric fan of my 92 XJ'40 is not working as it should, or perhaps not working at all. The needle of the temperature gauge used to stays on N even in adverse conditions : getting stuck in traffic on a very hot day for instance (with the A/C on, of course). Recently, I noticed that in similar circumstances, the needle went further right (never reaching the red zone though).
- Should the fan be running as soon as the A/C is on, or only when the coolant has reached a given temperature ?
- Is there a way to test it ?
First, I think I should check the fuse. Does anyone know where it's located ?
Re: auxiliary cooling fan
Posted: Wed Aug 25, 2010 6:56 pm
by robv12
first and foremost we need to know the model of car; as in 1992 we had both battery in the boot and battery under the bonnet cars, tell me which yours is and we can go from there
Posted: Thu Aug 26, 2010 10:13 am
by robv12
ok, now i know the car as a pre 93MY, I can have a stab at an answer!!
the aux fan will only come on at higher water temps, it is not connected to the a/c in anyway
the aux fan on early cars rarely , if ever, came on when the cars were used in the uk, the chances are that it has seized, or just had that much water and road dirt chucked at it over the years it will have failed,
I have a huge stock of 40 spares here, I keep just one aux fan as a just in case" but in reallity they go for scrap with the rest of the car
you could also check the water temp sensor at the botton of the rad, left hand side
if a fuse has blown you will have a tell tale on the dash
hope this helps and thanks for the kind words
Posted: Thu Aug 26, 2010 8:59 pm
by phirou
I can imagine that the auxiliary fan is rarely on in the UK (and even more so on the Scottish border) but it may be much hotter in central or southern France.
I understand that
1. The auxiliary fan is not connected to the A/C
2. It switches on at a given temperature.
I am trying to figure out how it may work :
The coolant temperature sender sends a signal to the ECU which in return sends a signal activating the relay ?
I guess I could first check if the motor is working by directly connecting it to the battery.
It the motor is running OK, the problem would be to simulate the signal sent by the ECU when the coolant has reached a high temperature. If the fan does not switches on, then either a) the relay could be at fault - change it .
b) the sender is faulty - change it
c) most improbable, the ECU is faulty.
What kind of signal should be sent by the ECU ? 12 volts to the relay ?
Now, it could be that the fan was doing its job on that very hot day, and that slight overheating was caused by a partially clogged cooling circuit and aging coolant.
It is now getting colder, and the problem has not occured again (though cleaning the circuit and filling it with new coolant would do no harm). I could do nothing or have it done by my local garage, but I would like to understand how it works : learning is one of the pleasures of owning an XJ 40 and there is quite a lot to learn !
Posted: Wed Jan 15, 2020 7:08 pm
by steve_m
An old thread that appears to have gone unanswered.
XJR6, cooling fan relay; I have a replacement and apparently it either goes behind the left hand headlamps somewhere or above the left wheelarch liner somewhere.
Can't see anything similar anywhere.
Anybody have any ideas?
Posted: Fri Jan 17, 2020 11:08 pm
by cafcpete
I think its Up behind the bummer. Having not had to play with it myself but I think I have a photo from when my car was rust proofed showing the item.
Posted: Fri Jan 17, 2020 11:10 pm
by cafcpete
Posted: Sat Jan 18, 2020 1:50 am
by steve_m
Many thanks for that, much appreciated.
Who ever thought that would be a good place to mount a relay....
Posted: Sat Jan 18, 2020 9:14 am
by cafcpete
Indeed lol
Good luck which changing yours.
