My stearing wheel is slightly off center
Den_XJ6
Postby Den_XJ6 » Thu Sep 03, 2009 8:59 pm
Hello
Iv noticed my stearing wheel is slightly off center, is this a faut with xj6/ Jaguars?
Is taken my stearing wheel off easy? as im thinking in popping it off, straighting her up and pop her back on? Only thing that puts me off is the airbag :shock: :? dont want her going bang in my face :D
Thankyou
Den
Straight6DOHC
Postby Straight6DOHC » Sun Sep 06, 2009 9:41 pm
Best not to touch the steering wheel to adjust it back to centre because then you'll be able to turn it more one way than the other when full lock comes round. Get the wheels aligned at a garage but make sure they centre the steering wheel and adjust both track rod ends. The squinty steering wheel phenomenon arises because garages take the easy (cheap) option and align the tracking by adjusting only one side of the car.
Den_XJ6
Postby Den_XJ6 » Mon Sep 07, 2009 10:31 pm
Ok mate, good thinking, ill look in getting her checked over.
robv12
Re: My stearing wheel is slightly off center
Postby robv12 » Mon Sep 13, 2010 5:53 pm
try the solution above first
airbag removal on 300 and 308 is straightforward, XJ40 is a little more involved, you dont say what model you have
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
jeff1954
Postby jeff1954 » Sun Sep 19, 2010 11:02 am
Hi Den
Have a look on the S Type bulletin board under steering and suspension you will find the answer there.
I did the job on my S Type and found it simple
PS You must disconnect the battery first and don`t forget the radio code
Jeff
Previous Jaguars.
1967 3.8 S Type.
Series 1 XJ 4.2
Series 2 XJ 4.2
