paint codes
barold
paint codes
Postby barold » Wed Apr 09, 2014 9:44 pm
Looked everywhere, can't find the plate / label which includes the paint code.
So, please help. 1995 XJR in Torquoise. A colour I believe was created for this model.
What is the code? Thanking you in advance for your help here.
Need to get my wheelarches sorted. sound familiar?
Ta, Barry
Re: paint codes
Postby ptjs1 » Wed Apr 09, 2014 10:04 pm
Barry,
I suspect it's colour code - UDB as also used on XJSs. Type "Jaguar Turquoise UDB" into Google and you'll probably find a website that will show you the colour to confirm.
Popsjag
Re: paint codes
Postby Popsjag » Thu Apr 10, 2014 5:47 am
Hi Barry,
If I'm correct, your three digit paint code should be on the plate above the radiator near where the bonnet hinges - unless it has come off over the years!
Steve.
2003 X350 XJR - daily driver
Past vehicles:
barold
Re: paint codes
Postby barold » Thu Apr 10, 2014 8:25 pm
Steve, Thanks. Yes it's gone. A vinyl based sticker what! Maybe Ford thought that after 20 years identifying a paint code would be the least of our problems! :lol:
Paul, thank you , UDB sounds like a good start position. I'll order up a rattle can and see how it comes out.
thanks guys
Barry
robv12
Re: paint codes
Postby robv12 » Fri Apr 11, 2014 1:45 pm
this my default site for paint codes
http://www.affordablejaguarparts.com/in ... chart.html
UDB is indeed Turquoise, or in some cases I have seen it called Bright Turquoise, and, yes it was a colour launched to coincide with XJR 300 launch in 1994
