XJ6 Door Arm Rest
DavidEm
XJ6 Door Arm Rest
Postby DavidEm » Fri Aug 10, 2012 6:19 pm
Hi Chaps,
So, how do you remove an X300 driver's door arm rest?
X-308 Model Section Coordinator
2001 X-308 XJR
1996 X-300 XJ Sport
robv12
Re: XJ6 Door Arm Rest
Postby robv12 » Fri Aug 10, 2012 7:03 pm
top door trims and wood off in the usual XJ40/X300 manner, pop out the blanking plugs on the underside of the armrest and remove screws, the whole door card including the armrest will come away with some sharp tugs, it is held to the door by some plastic clips ans one large metal clip behind the armrest, disconnect and wiring for windows and puddle lamps, once you have the door card off, you will see how the armrest is held on with screws from the rear of the door card, undo these and disassemble as needed
hope this helps
Rob
88 3.6 XJ40 EX JDHT
88 3.6 XJ40 SOV
93 XJ40 XJ12
97 Daimler Double Six
97 XJR 300 Manual EX JDHT
55 X TYPE EST 3.0 SP PREM
56 X150 XK
DavidEm
Postby DavidEm » Fri Aug 10, 2012 9:05 pm
Brilliant... thank you Rob!
2001 X-308 XJR
1996 X-300 XJ Sport
