Courtesy light not working
Posted: Sat Nov 07, 2009 11:28 pm
by Ejay
The courtesy light from my rear drivers side door is not working, all other doors are fine and operate the lights perfectly, however I cannot find the switch in order to try and rectify the problem, any guidence please??.
Posted: Mon Nov 09, 2009 12:28 am
by Brakebuster
i'm afraid the switch is in the lock
try swapping the lamp from the actual fitting, it may be as simple as that
Posted: Mon Nov 09, 2009 5:01 pm
by Ejay
Thanks BB I'll give that a try as I don't fancy removing the door trim!!
Posted: Thu Nov 12, 2009 6:20 pm
by Ejay
Any ideas how to remove the lens cover???
Posted: Fri Dec 11, 2009 11:51 am
by robv12
it just prises away from underneath, there is a little clip in lug that you need to clear, it then just slides off
