X300 1994 3.2 Wing Miror Glass Removal.
xjscharlie
Postby xjscharlie » Mon Apr 09, 2018 7:26 pm
Hello Folks,
Could someone pse advise the correct procedure for removing the wing mirror glass? I know that there's a proper way to do it and i dont want to end up breaking something. Advice appreciated. Thanx in anticipation. Charlie.
watto700
Re: X300 1994 3.2 Wing Miror Glass Removal.
Postby watto700 » Fri Aug 23, 2019 5:48 am
G'day Charlie,
If you can place something like a thin blade between the mirror and the body of the mirror housing at the inboard side of the mirror you should be able to lever it outboard slightly and the outer edge of the mirror should release from it's mounting. Gently does it though
A look at these pix may help
Cheers,
Jeff.
Popsjag
Postby Popsjag » Mon Oct 21, 2019 8:23 pm
This topic has been moved to the 'Bodywork' Section.
2003 X350 XJR - daily driver
Past vehicles:
