Heated Windscreen x300 Sovereign
Was a heated windscreen standard fitment on 1996 x300 Sovereign, any one tell me as mine has windscreen out and there are two wires each side behind the trim, the windscreen that was removed was not heated. there is a switch for heated screen on the dash.
Re: Heated Windscreen x300 Sovereign
don't know about ' standard . but i think it was an option
if installing a new screen , and its heated, you will only need a pair of relays , and the dash console over the stereo with the heated screen button option , it will be next to the rear screen heater switch , and from memory they made two switches fit in the space the single rear screen switch takes
Ford owned the copyright to heated front windscreens screens, and as they owned Jaguar back then it was fitted into Jaguar cars
i think Sovereign spec should have had it as standard? its possibly been replaced before with a standard screen. if the button is there it should have had it from the factor, I reckon.
the switch pack was available with or without the heated screen switch, so stands to reason.
91 4.0 XJ6 Manual
92 4.0 XJR Manual
93 3.2S-4.0S Man conv
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
96 X300 Daimler Six LWB
97 X300 Sport 4.0 Manual
00 LR Discovery 2 TD5 ES A
03 X350 4.2 XJR
92 4.0 XJR Manual
93 4.0 Sov
93 6.0 XJ81 DD6
93 6.0 XJ81 XJ12
94 4.0 XJR
96 X306 4.0 XJR
03 X350 4.2 XJR
no ,
i had a sovereign , without heated windscreen , and it still was an option right up to year 2001 , when they started fitting all the stock left over that wouldn't fit the new aluminium cars........
