I have a manual XJR XJ40 with some rust holes in the inner wings.
Can these be repaired or is it the death of the car? Also I
have some rust and a small hole appearing on the bulkhead?
I'm guessing it won't be structural or weldable but can I
just cut the rust out and maybe mesh and fill the hole??
Thanks,
Steve.
Rusty inner wings
Fantastic!!
I have been trying to find a Jag specialist in Swindon for weeks.
Could you mail me your contact email and maybe numbers?
My email is steve@jaguarsport-xjr.com
Thanks,
Steve.
Thanks,
Steve.
Steve, rusty inner wings and bulkheads are common with 40's, they are not the death of the car, but a good repair can be tricky especially to the bulkhead, I'm sure you want your car done to the best possible standard and not some of the awful 'bill the boger' to mot standard, not, repairs that I have seen here
The bulkhead rot is caused by water build up in the void under the windscreen, this is caused by the rubber 'duckbill' drain on the bottom of the wiper motor clogging up hence the water is retained and corrodes the bulkhead from within, again i've seen some horrors here, strictly speaking an mot fail, but most testers seem to miss it
Hi Rob, we haven't spoken for a while.
Thanks for the advice, I have spoken to Alan Proctor (as recomended on here) and also Keith Parrington of xjrestorations with regards to a quote for the repairs. Keith has some nice pics on his website of rusty innerwings an bulkhead on an XJ40 that he has already done. Also I have mailed the guys in Wooton Bassett that was also recomended on here.
In case you hadn't realised, I now have 2 XJ40 XJR's sitting on my drive!! Hopefully I will be getting them both restored although I think my first one may be a bit more terminal than my new one. It hasn't been started for 4 years and has been sitting in a garden, so I imagine the underside to be fairly rotten. I need someone that knows what they are looking at to crawl underneath and assess whether it is a waste of time even trying to get it back on the road.
Oh well, the joys of owning an old Jag!
