I'm getting poor heater output until the car has been run for a good while and then only when out of town and driving faster. So far the heater pump has been replaced to no avail. The engine warms up quickly so that rules out the thermostat and the hoses are all hot around the pump and the valve. I've thought abouit trying a new valve in case the original is only partly operatiing, but a quick check on the internet suggests only second hand ones are available at around £40. Are there some further tests I can run? If its not the valve the next obvious suspect is a blocked heater matrix, which I assume is a pain to replace. Are these prone to airlocks and is there a procedure for testing flow? Would disconnecting the hose on the return side of the heater circuit give an indication?
All suggestions gratefully received. Regards, Chris.
Poor heater output
ChrisDixon
Chris
'95 XJR Manual
'86 XJ-SC 3.6 Manual
'95 XJR Manual
1990 xj40 heater
With no heat to the floor whatever i decided to let someone with the experience have a look.......i had exhausted other options ......The problem turned out to be rather a shock...
One of the swivel pins on the main outlet flap to the cabin had broken and to replace it meant having the heater taken out en block......then a new pin either made or buying a new one ........then after servicing the rest of the heater while it was out of the frame you have to install it back in.
With an XJ40 it is never guaranteed to go back as it came out and possible other items of wear and tear become evident. So a very expensive episode....the alternative was either buy a new heater or keep sticking your screwdriver up the flap in winter to allow the hot air to the footwell then in summer pull it back down to keep your feet cool.....
descisions descisions.......Oh to own a Jaguar
