Reading the owners manual it almost says Go to JLR , Do not pass Go , do not collect £200 , Frightening.
Could it be a Duff sensor , Bad earth or other connection ? if so where can these be accessed
Thank you in anticipation . Chris
Only 86-89 XJ40 have that over voltage relay. its not applicable to later XJ40 or X300.Take a look at the overvoltage relay..... if it’s the same as the XJ40. From what I can remember it’s located in the boot l/h side the largest on there!
Also check for swarf/dirt on the phonic wheels where the sensors mount.
Dave
