Squeaking noise from rear when on 'D' and braking
Posted: Wed May 18, 2016 11:54 am
Hi!
As the title says I've noticed some funny noise coming from somewhere at the rear (axle?) of the car. It was quite tricky to get it reproduced systematically since it is almost not noticeable from inside. When moving slowly on 'D' (accelerating or decelerating or just maintaining the spped), so that the brake pedal is pressed and I haven't got my foot on the accelerator at all, if the car is going over some uneven surface or at least a bit up/downhill I start hearing this, sometimes loud, squeaking noise from the rear. And it only happens in this 'setting'. If it is on 'N' or 'P' however bad I shake it there is no noise at all, so I think it is not the suspension. Also, the sound is quite different from what you get when the breaks are wearing off or when they 'cling' to the disc when pressed for long. Moreover, the car had recently had all brake discs and pads replaced and checked, so I also think this is not the brake problem.
The problem was going on for a while, but I couldn't pin down the conditions under which this happened. In the meantime, the car passed a few MOTs and services without any problem in this part.
Does anyone have any similar experiences?
BW
Max
BW
Max
