X300 Stuck in Park
This hasn't happened yet but.. sometimes the auto gear shift doesn't want to come out of park when I press the brake pedel. Is there a procedure to open up the cover and move the shifter? If this becomes a problem Thankyou Graham Matthews
PeterDavisX300
Re: X300 Stuck in Park
There is a procedure, you carefully remove the little plastic torx drive in the gear-selector console, and press down to release manually. Unfortunately this usually results in ruination of the console bitty. Best to check the fuse within the rear drivers-side 'kick-panel' at your heel under the rear seat, it's also the cigar-lighter fuse, it blows, if you load-up the cigar lighter with say...... a wee compressor for the tyres, or something heavier than it's designed for. When that fuse blows, the 'interlock' for Park-release is goosed. Try this, and get back to us, it's always important to 'follow-up' on a problem, it allows us to learn the foibles.
Peter
Peter
1984 Mercedes 450SL Rag-Top
Thanks for the info. Peter, I will check the fuse first. At the moment, all is well on the second attempt to get out of park. Hopefully I'm panicking unneccesarily!.. Graham
This topic has been moved to the 'Transmission' Section.
2003 X350 XJR - daily driver
Past vehicles:
Past vehicles:
